Technical advise on setting up the flat shift on an emerald ecu
Hello Guys, I'm looking for a little technical advise on setting up the flat shift on an emerald ecu, I've installed it fine and I'm good with all the settings apart from the engine control, retard ignition to part. At the moment the default setting seems to be -10.0 "BTDC, it will allow me to go upto -30 "BTDC.
The ecu is running a 20v Audi S3 lump with an impreza turbo, the emerald instructions says that on turbo cars that retard ignition timing acts as a form of antilag.
The car is currently off the road so I have not tested it yet but have not idea what to set the retard ignition to, any help would be appreciated.
Thanks
James
Thanks
James
