any central heating engineers??
can you help? central heating boiler just packed in!![](https://passionford.com/forum/images/smilies/shocked.gif)
when hot water is run it fires up and stays rubbing,but when i turn c/heating on it fires up then instantly shuts down,fires up again and does the same! whats the cause?
could be your central heating pump not running, small screw on the side (silver/flat bladed screwdriver required) undo it and turn heating on and if you can see the shaft turning or hear it come on then its all good, if not, its not so good, could be a few things on top of that, like a thermostat etc
09-10-2015 07:38 PM
track.focus'd
12-08-2015 05:53 PM
