JE Pistons & Ring Gaps on Zetec Engine
hi all i have a set of je pistons to put in my focus rs engine! the block has been honed to the correct bore size and is all ready to go! know how check the ring gaps just need to know if anyone knows what they should be set to on this type of engine and also if they are out how do you adjust? thanks in advance
Ben....
Ben....
the ring manufacturer will give you a spec depending on the power you are running. You then place them in the bore, and file them to the desired clearance.
Rick.
Rick.
JoeyBoyden
04-01-2024 02:36 PM
Zoggon
10-08-2015 10:39 AM
