bd10 cams
already buying the bd10s as im building the engine from nothing,ive got a 205 block with machining for wire rings,got standard crank and a set of standard rods coming,got a standard 2wd head thats bere so will probably keep it aside for a later date to have work done on it,ive also got a 4x4 inlet manifold aswell,im looking at getting between 350 and 400 at the moment,but once the car is up and running i will be starting on another engine slowly with the hope of a bit more power and strength,so will be using a 200 block and h section rods and headwork aswell and will probably have to got to rwd then
Mc5506
05-10-2015 09:57 PM
