engine / mechanics experts
Old Apr 15, 2009 | 04:56 PM
PGT's Avatar
PGT
Default engine / mechanics experts
when i crank my YB without plugs in there is air pressure pulses from the engine breathers - why is this? if two pistons go down then two also go up at the same time thus the volume of air in the block remains the same surely?
the engine is in perfect condition and whilst the (two) breathers may be in different parts of the block (usual points) i can't see this being relevant anyway - why the pressure pulses?
Old Apr 15, 2009 | 06:06 PM
jammy86's Avatar
jammy86
Its dependant on the interbay breathing area. The air will always go the path of least resistance, which in this case must be the breathers.
JAmes.
Old Apr 15, 2009 | 06:24 PM
Dan1281's Avatar
Dan1281
JAmes.
yep, wouldnt worry about it, the breathers must be closer to the bottom of the pistons than the other oppositely moving pistons
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mark Mawson
Aug 31, 2015 07:09 PM
vdubo7
Aug 2, 2015 08:17 PM
