Spark plug gap?????
Old Apr 12, 2009 | 09:06 PM
escosworth1's Avatar
escosworth1
Default Spark plug gap?????
Ok so ive got a bt escos which had a slight missfire when standard. So I fitted a group A coil and gapped the plugs to .7mm and all was well.However ive since fitted a full mongoose system and large cone filter and its now missing again. I changed the gap slightly to .65mm but even worse so should i be opening the gap up. Thanks Rob.
Old Apr 12, 2009 | 09:08 PM
KSA-Cossie's Avatar
KSA-Cossie
What plugs m8 ? How old are they ?
Old Apr 12, 2009 | 09:09 PM
escosworth1
new plugs mate cant remember the make off the top of my head to be honest.
Old Apr 12, 2009 | 09:45 PM
escosworth1
anyone
Old Apr 12, 2009 | 09:47 PM
KSA-Cossie's Avatar
KSA-Cossie
I'd try another set of plugs m8,especially if they're 071's.
Old Apr 12, 2009 | 09:50 PM
escosworth1
there not 071s i no that much lol
Old Apr 12, 2009 | 09:52 PM
KSA-Cossie's Avatar
KSA-Cossie
The lead from coil to dizzy isn't running near the map sensor is it ?
Old Apr 12, 2009 | 09:54 PM
escosworth1
It could well be ill have to look why can that affect it.
Old Apr 12, 2009 | 09:55 PM
cossiedave's Avatar
cossiedave
would this have this afect m8
Old Apr 12, 2009 | 10:09 PM
KSA-Cossie's Avatar
KSA-Cossie
Yeah,could be cps or phase sensor too.
Old Apr 12, 2009 | 10:22 PM
escosworth1
hmmm ill try opening the gap and see what happens
Old Apr 13, 2009 | 07:32 AM
Too small a gap is unlikely to be the problem, could just be one duff plug.
I would use some Iridium plugs as these require much less voltage to fire, and seem to resist fouling better too.
Old Apr 13, 2009 | 07:34 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
They don't work well in all engines
Steve
Old Apr 13, 2009 | 09:01 AM
escosworth1
When I made the gap smaller it wouldnt idle hardly at all made it much worse.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
