ST170 head/Zetec turbo timing belt question
So my engine is very nearly finished ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
![](http://i3.photobucket.com/albums/y70/XRT_si/15032009365.jpg)
Its a silvertop bottem end with a ST170 head, but went to put a timing belt kit on it today and had a few issues with idler set up. Its a silvertop cam belt kit I was using.
Has anyone else used this set up?
Iam sure I could make something work with a bit of time just wondered if there was a easy solution to share that would save me a bit of time!
YES I KNOW I CANT SPELL
the silver top tensioner is more to the middle from memory ,just use a blacktop belt
Crack on you arrogant prick.
There's no need what so ever in the slightest for your derogatory and purposely demeaning posts.
Its perfectly clear from my original post exactly what I meant, as everyone else understood it perfectly.
And if you dont know enough about Zetecs to guess what water pump set up I'll be using on a silvertop engine I suggest you stop trying to make yourself out to be the leading authority on Zetec Turbos. This is not my first Zetec Turbo sweetheart
Go run along now
![](https://passionford.com/forum/images/smilies/roi.gif)
And if you dont know enough about Zetecs to guess what water pump set up I'll be using on a silvertop engine I suggest you stop trying to make yourself out to be the leading authority on Zetec Turbos. This is not my first Zetec Turbo sweetheart![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Go run along now![](https://passionford.com/forum/images/smilies/roi.gif)
Go run along now
