Boot mounted batteries
what one to go for?
all the 3dr has is the lighting circuit, dash/dials and the ecu that needs power.
the batt is going in the boot so i of course a std one wont do as i dont want a facefull of acid if i bin it...
so, what one to go for?
http://www.merlinmotorsport.co.uk/p1...duct_info.html
or
http://www.merlinmotorsport.co.uk/p4...duct_info.html
what would best suit my needs?
will be buying from here
http://www.merlinmotorsport.co.uk/BA...110/index.html
cheers all
or
cheers all
As said a plastic box and std battery is cheaper, though a lot replaced due to weight in a track car.
AGM as in oddesey can still crack/break open in impact and shower you with acid, the bonus here is the gel helps to make it stick better to your skin!!
hope this helps
paul
Optima are certainly good, they use a spiral agm, so are wet in that they have a gel, as they don't need topping up, and you can't as they are sealed a lot of makers call these dry, but this makes them very suitable for long periods of no use, as sulphation cannot occur.
Despite what is said give any battery enough impact and it will break, like anything else will.
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
