Anyone got 362mm discs under 8x18 old style mo's
06-04-2009, 03:28 PM
Did you have to use a spacer ?
06-04-2009, 04:52 PM
is their much difference in space for disks in the old and new style comps.. ie will the new style fit bigger disks?
06-04-2009, 05:37 PM
ive had to fit long studs
06-04-2009, 05:39 PM
B1mbo
380's will go under old style
thats with no spacer ,
although, its the correct offset for the car, so if yours is a different offset to which it should be then you might need a spacer i guess !
jim
06-04-2009, 07:06 PM
ive got 380mm under new comps although 2wd but no spacer.. caliper real close to the wheel though.. 3 or 4 mm..
06-04-2009, 08:56 PM
Mine were off an escos et35 wheels needs spaced 3mm.
01-11-2015 06:53 PM
07-10-2015 12:56 PM
locum8
01-10-2015 01:50 PM
SMILER258
28-09-2015 09:04 AM
IainRS1700T
25-09-2015 06:44 AM
