advent laptop fan on constantly
it went off for repair received it back today all working fine
but i have noticed from the monent you switch it on and all the time its on the fan is on, bloomin loud they can be too
now i cant remember if it done that before as i havent used it for a couple months and was using a friends one
any ideas? its a advent 5401 they aparantly fitted a new motherboard whatever that is lol
it's doubtful it's supposed to be on all the time, i only ever hear the fan on my laptop when converting video or when i have it sat on the duvet and theres little airflow, laptops are designed to run cool during normal operation.
The fan on my HP is on almost all of the time. Check the BIOS settings as there is an option on mine to run it continuously on AC power.
Shanny
Shanny
I dont know much about laptops but my old one i use for wireless around the house has got a air vent on the bottom of it, so if sit with it on my lap the air cant be drawn in, so it will get hotter and hotter.
I would guess they havn't fully screwed the heatsink assembly back onto the cpu properly and its not making full contact causing a serious hot spot. This would make the laptop think its cooking and thus put the fan on full speed. I may be completly wrong but thats my thoughts. If there is a flap underneath for cpu inspection it is worth taking it off and checking the screws to make sure they are fully tightened.
Hope this helps.
Regards.
Adam.
Hope this helps.
Regards.
Adam.
i got a advent lappie to an my fans on constant its really load but i just get on with it at least i now its staying cool an not overheating theres a button on mine to turn the fan on or off but it dont work lmao
i think ill leave the bios bit alone, i was rebooting a few times trying to get into bios pressing f keys etc and screwed the whole thing up ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
it wouldnt boot up self recover menu bit was screwing up after 30 mins i got it to load and its working again now naturally the fans cooling the whole living room but its working lol
as above make sure its on like a wooden surface and not your lap. there is no where for the air to get in and out otherwise.
fan shouldnt be on all the time tech support taking the piss lol
wheelwizardrefurbs
23-09-2015 09:21 PM
