Basic setting up for steering tracking ??
Old Dec 2, 2004 | 11:12 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Default Basic setting up for steering tracking ??
As above, need to know if there is a basic setting cause i thing my tracking is out.......
Old Dec 2, 2004 | 11:22 AM
CabrioTurbo's Avatar
CabrioTurbo
connect the Track control arm?!
Old Dec 2, 2004 | 12:34 PM
Adam_BlackRS
Ex Ford Man
When the wheels are straight, they are like this....
Is it just a case of adjusting till there straight ???
Old Dec 2, 2004 | 03:01 PM
Adam_BlackRS
Ex Ford Man
Old Dec 2, 2004 | 03:07 PM
Smit's Avatar
Smit
The 60ft Launch King
Adam, Surely as the car is up in the air they will sit a little out....but what they like when some weight it on it? (being on the floor) They shouldn't camber outwards that much surely
Ever thought about getting some adjustable bottom Arms like C+B have?
Old Dec 2, 2004 | 03:13 PM
boost mad's Avatar
boost mad
Old Dec 2, 2004 | 03:14 PM
ballin's Avatar
ballin
pmsl
Old Dec 2, 2004 | 03:17 PM
Adam_BlackRS
Ex Ford Man
Smit, on the ground the wheels are sitting like \---/
I have a adjustable TCA's but camber is not my problem, its the tracking
Guess i just need to keep adjusting the track ends till there straight
(No, i can't get it to a alignment place, before anyone says)
Old Dec 2, 2004 | 03:35 PM
AlexF's Avatar
AlexF
But at some tracking places can get to you....!
You want the wheels to be about:
toe out looks like:
toe in looks like:
You need a little of toe (either in or out it depends on the car fwd/rwd).
You also need to make sure the back wheels point in the right direction as that is EVEN MORE important!!!!
Alex
Old Dec 2, 2004 | 03:48 PM
Adam_BlackRS
Ex Ford Man
Alex,
Yeah, mines Toe out at the mo, or one side is more than the other.
What i'm trying to find out if is there is a basic setting i.e screw the track end all in the way in and turn it 4 full turns each side
Old Dec 2, 2004 | 06:05 PM
Smit's Avatar
Smit
O right getting ya now!
My runabouts tracking fucked up ended up getting it lasered...they put the steering wheel dead staright..click the steering lock on and then undo the track rod ends......move the wheel straight (with the aid on the lasers which are attached to the wheels! and wind them/on further/off further then lock them with the nut...and hey presto! | --- |
well that's what happens anyway
Old Dec 2, 2004 | 06:12 PM
edd's Avatar
edd
standard toe setting on erst is toe out 1.4mm
Old Dec 2, 2004 | 06:13 PM
edd's Avatar
edd
Originally Posted by blackRS
Alex,
just saw this.
answers no
Old Dec 2, 2004 | 06:15 PM
AlexF's Avatar
AlexF
no theres no std start point...
just do it buy eye and then get it setup
alex
Old Dec 2, 2004 | 06:26 PM
Adam_BlackRS
Ex Ford Man
Cheers peeps, hope my eye sight is straight !!
Old Dec 2, 2004 | 06:29 PM
AlexF's Avatar
AlexF
It wont be...
remember my minis 1st outing at bedford?!?! (track attack 2)
It was hopeless!!!
You need to get it setup.... hence why I brought the equipment to do it
Chas
Sep 21, 2015 08:57 PM
FlashRS
Aug 30, 2015 08:07 PM
Jay,
Aug 24, 2015 05:26 PM
Steve Escos
Aug 24, 2015 07:56 AM
