General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Many thanks to Tony @ Turbosystems for getting this made, very nice bit of kit and i'm told alot of work to make it, in particular the internal baffling system to seperate oil properly. Also liked the bracket to mount it to the engine mount rather than having to drill and tap the block:
£430 for a used beer can with some pipes hooked to it?
Wanted one of these since I first saw one years ago but how does it fit to 4wd? I seem to remember a post on here that it was a pain in rear to fit?
They are a pain to fit on a engine in the car, really it's a take the inlet manifold off job. Also you need an additional place on the engine to breathe from as this has 3 inputs, i'll be breathing from original block breather, front end of engine and exhaust side of engine.
Originally Posted by Vic
tony, do you reckon that these will fit with a MIS inlet manifold?
They should fit with a MIS manifold no problem, i noticed last night when mocking it up that this one mounts to the bottom of the inlet manifold flange rather than the top like the original ones, should make install abit easier
