fitting airbags to a mk3 golf?
hi al,
my mate has got some suspension airbags for a mk2 golf.
is there anyone in the hampshire area that could fit em? he would pay, car is very tidy and currently in bits lol. he and i just dont have a clue
cheer
matt
cheer
matt
1 Post
its not just a matter of the bags,
there is the body sensors, mods to the body for them fit, the loom, the ecu - very specialist, and could cause death or serious injury it not right!
Proven Legendary Status
Do you mean Airbags as in the large things that defen you in an accident, then imbed your sunglasses permanently into your brain. Then burn your exposed flesh.
Or (as I suspect) do you mean airbag suspension?
airbags have only one connection? ive removed and fitted loads in salvage cars just unbolt it and bolt in the new one, just make sure the batts disconected prior for atleast 30 mins
no you didnt miss read mate, i just put 'airbags' origionally!
im not sure on the kit, its a friends car, it cost Ł1200, i don't think it came from the states though!
tbh the best person in the uk at the mo is Ray (rayvern hydraullics) he probably does one or two dubs every week with one of his bag set ups but if its not one of his i doubt he would be too helpfull .
the best thing to do in your mates position is go onto this forum http://www.unitylowriderforum.co.uk/ and let the guys there know as much detail on what you have with the kit , there will be someone there that can guide you through the whole fitting process .
afaik fitting bags on a golf is a pretty straightforward procedure should be simply swapping springs for bags and conecting up the air lines to the compressor and tank and wiring up solenoids and control box BUT if its not a well built kit you may need to do some mods on the cars original set up .
hth
hth
1 Post
no idea, never heard of them being fitted to a golf tbh, but im not very well up on the golf scene.
get your self on www.edition38.com and ask on there
Canny VAG forum, someone should be able to help out
paceo
03-02-2016 10:31 AM
