rear diff failures
Old Mar 25, 2009 | 09:00 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default rear diff failures
what is the most common failure of a rear diff?
is it because of the casting flexing?
reason i ask is because i was sold a 4x4 rear beam and diff as a 2wd item (didnt know any better at the time as it had the 3dr swingarms and rear arb...)
anyway, i am hoping for around 400ish bhp when the 3dr is up and running so thinking about getting a strengthening plate made up.
or failing that, i have a spare diff that i will get welded lol
Old Mar 25, 2009 | 09:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
pinion teeth breaking due to too much torque
or ask jb
Old Mar 25, 2009 | 09:07 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
isnt that something to do with the case flexing tho?
or not lol
Old Mar 25, 2009 | 10:23 PM
dojj's Avatar
dojj
no mate, i think you are thinking of the front where the pinion climbs the crown wheel teeth because the casing flexes
resluting ni the thick walled casings available form various leading providers of thick walled ford front diff manufacterers
in the rear you either live with the 7.5 inch diff (you've got the 7inch one) or yougo up in size to a 9 inch of a jag diff, the bits that you can uprate aren't the pinion or crown wheel
with 400 brake and rwd i don't think you'll give it nightmares, but a step up to the 7.5 inch diff (you'll need the 2wd shafts and outputs etc to go with it if you want to upgrade to the 2wd cossie stuff) would be the next step up from the likes of a granada (the 24V has an lsd in it)
Old Mar 25, 2009 | 10:31 PM
COLEYST200's Avatar
COLEYST200
is the granada (the 24V has an lsd in it) better or the same as a 3dr 2wd 7.5
Old Mar 25, 2009 | 10:32 PM
RONNIE AMIS's Avatar
RONNIE AMIS
i think the granada one is a 3;6 to cossie 3;9 better for bottom end i think, any one know where i can get one?
Old Mar 25, 2009 | 10:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ah it must have been the front diffs i was thinking of then.
i have thought about changing to propper 2wd stuff, but that means changing the hubes etc too, so may as well get a complete 2wd rear beam etc.
but i cant be arsed nor have the spare cash at the mo so ill stick with the 7" and if it blows, get the spare welded lol
Old Mar 25, 2009 | 10:41 PM
dojj's Avatar
dojj
the granada 24V is a 7.5 in 3.62:1 with lsd and 100mm output flanges
the scorpio 24V is a 7.5 in 3.62 without lsd and 100mm outplut flanges
the 7.5 3.92:1 diff's are found behind the dohc engined sierra's 90-92 spec vintage, again with 100mm output flanges
the dohc 4x4 cars also had a 3.92:1 front diff
Old Mar 25, 2009 | 10:43 PM
RONNIE AMIS
good info mate, looks like i'll be going breakers lol
cheers
Old Mar 26, 2009 | 06:18 PM
col cos1's Avatar
col cos1
what dohc sierras had a 7 1/2 diff?
the 2.o xr4x4 surely be a 7in
and a 2wd ghia/gls surely isnt lsd ?
Old Mar 26, 2009 | 06:19 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Most common failure at the moment appears to be a Nordic trait of putting a 7" diff in a 500bhp RWD cossie and expecting it to last longer than 200 yards
Old Mar 26, 2009 | 06:55 PM
dojj's Avatar
dojj
all of the 2wd ones did, but in a 3.92:1 ratio
yes, but, again, in a 3.92:1 ratio
nope, you are correct there
although some granada's had the towing pack, which included a 3.62:1 7.5 inch lsd diff
and some had the taller 3.36:1 diff in them
Old Mar 26, 2009 | 06:57 PM
col cos1's Avatar
col cos1
some useful info there mate
Old Mar 26, 2009 | 07:03 PM
dojj's Avatar
dojj
when it's cheaper to buy a whole car for the diff than buy the diff on it's own, it's taken a lot of cars
i even bought a diff from sweden, but it was worth the money as it was a 3.14:1 7.5 unit
138 mph in 4th @ 6000 rpm
Old Mar 26, 2009 | 08:37 PM
col cos1's Avatar
col cos1
ive had a few sierras myself,gutted how many ive scrapped now
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Fezman1
Sep 7, 2015 09:34 PM
