netgear wireless router setup argh
Bought a reconditioned netgear wireless router off ebay, its come today, and can i bugger get it set up.
Did everything according to instructions, but when i type in the 192.168.1.1 it brings up the box, says to put admin for the first box, then for password to type " password" and it also says this on the back of the router
but it keeps saying authentication failed, and to contact administrator.
Rang virgin, they want nothing to do with it and wont help ( obviously
So wondering if anyone on here can help out?
Its a netgear rangemax WNR854T
someone please help![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
Sarah
![](https://passionford.com/forum/images/smilies/angry.gif)
someone please help
Sarah
try restoring it to factory settings using the reset button,,
try this twice and see what hapens,,,
had the same today with a netgear router, reset it but still wouldn`t log on... tried a second time and worked...
Summer time Fezzy RST :D
just finding my feet
have you turned off the pc, modem and router,,, then turn on the modem, then the router and then finally the pc
when i got a new pc i couldnt get wireless modem to work,, tired all what you done then just gave up and put it in a box, a few weeks ago i tried again, searched on the net and someone sugested the turning on order has to be done or it wont work, i gave it a go and im typing from my powerbook g4 on wireless right now !!!
yeah i did it int he right order
this is the message im getting
"The server 192.168.1.1 at NETGEAR WNR854T requires a username and password.
Warning: This server is requesting that your username and password be sent in an insecure manner (basic authentication without a secure connection)."
im sure its connect all up,,,, then turn on the modem from the switch let all the lights sort them selves out,, then the modem and let that sort it out and then finally the pc and then see what happens
it it doesnt work 1st time, try again lol
mine is exactly the same but i got mine from virgin!! tried every combo of passwords i can think of, admin, password, administrator everything and it just doesnt work reset it numerous times as well!!
As Ginge said, you need to turn everything off and then back on one at a time (router then modem then PC) as LAN networks aren't quite as UPnP as they claim! Specially with Windows!
Now I pressume you are getting this message when you type in the 192.xxxxx url?
![](http://i41.tinypic.com/qxqb1k.jpg)
But it's not accepting the username/password combo you are trying, am I right?
If so, then as paul1rs says, you might need to try and reset it, as the stock username and password probably haven't been cleared correctly, if at all.
But before doing a hard reset, try using the default username/password. By default, the default username is [/b]admin[/b] and the default password can be any of the following : password, pass, 1234 or user
If none of the above work, then it's time to try a hard reset, as follows;
If the router was not cleared, try these additional steps AFTER the router has finished rebooting;
If none of the above works - it may be borked!
But do me a favor, have a look on the bottom of the router and tell me what revision the WNR854T is - it could be something like FR314, FR318 or FV318. If it is, these routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding.
- Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
- Release the button
- Wait for the router to reboot
- Try to log in with the default password (username : admin / password : password)
- Unplug the router's power.
- Press and hold the reset button. While the button is held down, reconnect router's power.
- Continue to hold the reset button for 20 seconds after reconnecting the power.
- Wait for the router to reboot.
- Log in with the default password.
well its connected now, via ethernet through the modem, so gonna try and unplug it and see what happens, i reset it and i got the router wizard coming up, and its saying successful, but ill unplug it and see
its saying its connected, im now not wired and it appears to be working, but its saying unsecured network so i dont want that, as i need to put a password on it so its secured? and for some reason we now have 2 connections active instead of one? lol
As for the unsecured part - you need to get into the router settings (by typing 1.2.168 blah blah into the browser) to access the router config and change settings - such as adding wifi security password
go onto wireless settings
click wep , or something to that wording, 1 st option i think
then at the bottom of it should be a button saying " generate,,
this will then give you your ssid key for the wireless for the 1st channel i believe,,
this what i did thismoring as well as i can remember ,, lol
Series 1 4x4 cossie
GET RID OF IT!
I have had the same one for just over a year.... i work away month on month off and weach time i am home i have to phone the fkrs in india to sort it out (which might i add has now run out and they want more money) total sh*te. cant wait to get rid of it. getting sky installed this time home and they said their router has wireless they send me and that will sort out all my probs????? hope so!
right I did what Thrush said to make it secure, now its knocked it off and its saying the settings on the computer do not match the requirements of the network and i cant get back on it, now bloody wired again
SMILER258
28-09-2015 09:04 AM
truffleshuffle
10-09-2015 09:35 PM
