bedding in new pads...??
saff is working!!!...atm
i know u have to go through a bedding in process when u get new discs n pads.......heat cycles etc.........but whats the process with just new pads.....cheers Pete
Last paragraph says about doing the breaking in process for a second time especially when putting new pads on used rotors
After the first break in cycle shown above, the brakes may still not be fully broken in. A second bed-in cycle, AFTER the brakes have cooled down fully from the first cycle, may be necessary before the brakes really start to perform well. This is especially true if you have installed new pads on old rotors. If you've just installed a big brake kit, the pedal travel may not feel as firm as you expected. After the second cycle, the pedal will become noticeably firmer. If necessary, bleed the brakes to improve pedal firmness
slammedorion
15
01-11-2015 07:17 PM
23
12-09-2015 12:56 PM
