Saph Damage Repair input needed.
I know not a lot about front ends of Saph's have a look at these photos and tell me what you think would need done to repair. I guess, wing, bumper, slam panel(is it removable?), lights and possibly bonnet??
slam panel is spot welded,the car is sitting a bit squint so maybe some suspension and chassis damage,the wheel looks like its been pushed back also.maybe a bit of fettling to the inner wing aswell.and a radiator as theres a puddle below it.a pair of bonnet hinges,it looks a bit like the roof has been pushed up,it would be better to get a full side on pic of the passenger side.
escort mk4 cossy 4x4
Resident Wrestling Legend
don't look like there is anything wrong with it other than the wing
the bonnet will straighten up easy enough too and everything ont he front end will repair real easy
there is enough adjustment ont he lights to make them look spot on and there doens't appear to be any damage to the front chassis meber at all
also, the door shut lines look spot on so it's very doubtfull that there is anything chassis wise that's bent
It's only a scratch, inner winng will need beating back into shape, plus the other stuff mentioned, look to see if chassis has any ripples, though they are very strong at the front, the wheel being back is most likely the shit weak tca is bent and the arb too, the top strut area will straighten no probs with shove.
The bonnet is twisted to fook, its also done the slam panel and part of the inner wing. I should also think the wing has gone back and damage the door.
Dont get me wrong though, its still repeairable though, all comes down to how much it sells for.
from what i can see, slam panel and wing is what's needed and a new light and bumper and possibly some suspension steering damage as to why the wheel is no the same direction as the other
the wing, in the picture, looks like it's still in line with the rest of the door and even at teh bottom of the a piller, so it's not like it's take a head on smack, more of a crease along the side
i've repaired plenty of bent bonnets in my time, that'll come out no sweat
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
