Wideband gauge
Just use a wideband gauge with the wideband sensor/controller...Take two bottles into the shower? Not me!
From what I understand narrowband sensors/gauges are better off in the boot anyway.
Im looking at something like this, but didnt know if i could use just one Lambda sensor.
http://cgi.ebay.co.uk/Innovate-DB-Re...2em118Q2el1247
Steve
Steve
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
You don't want to interfere with the signal from the lambda into the ECU on a closed loop conversion.
Cars that are running one lambda sensor for 2 purposes generally seem to throw lambda errors and struggle to lock to lambda at idle and under cruise.
I'm using the AEM wideband lambda kit with my AEM ECU, one lambda sensor for 2 purposes - BUT mine has been designed to do that
that link you have has a wideband controller which provides an emulated analog output to feed into the ECU.
providing it works properly (which i have no real experience with) it is fine
so it goes lambda -> controller/gauge -> ECU
I use XD-16 innovate kit and it work like oem lamda also. closed loop worked fine - it hold 14.7afr. and I didn't change any settings, just connect to ECU analog output. and XD-16 digital gauge has better precision then analog gauge from link, better to use xd-16.
there is a forum for innovate which maybe of some use
here..
http://www.innovatemotorsports.com/forums/index.php
here..
Innovate seem very hit and miss at the mo as to whether they work or not, they dopn't seem so much to fail, just don't work to start with a lot of them.
Had two for a TVR, both duff, but was mapped without(closed loop) anyway perfectly.
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
