Better Brakes.
Better Brakes.
Hi All,
I was thinking of better brakes, which other brakes fit the Granada 2.9, I was told the Mondeo 273mm will fit with the 5 studs.
Was wanting to upgrade with another ford brake and not aftermarket brakes kits with a ££££ tag.
Many Thanks
Alan
Many Thanks
Alan
No mondeo uses 273mm discs, what size wheels have you got ?
I would try decent pads first, as these can still be used if you still want to upgrade to larger discs so will not lose anything.
Grooving/dimpling makes a massive difference, I would recommend either EBC redstuff ceramic or yellowstuff pads, I use these myself on my cossie, and just can't fault them and I really am, heavy on the brakes.
