Chemical Metal Stuff
Anyone here used it??
want to get some to block 2 holes on a fuel regulator housing, will it be ok to use with petrol and under 4 bar pressure, or whatever it is???
also, could it be used to stick a nut to me exhaust for a sparkplug to go in for a flamer kit??
cheers
cheers
My brother used liquid metal to fix a crack in the crank case on his bike He also used that and a bit of a biro to fix a water leak in his mate's merc
Needless to say he's not allowed within a mile of my car.
Americans use this JB-Weld stuff which might be ok for your exhaust? i say just take it to an engineering place they'll do it for next to nothing!
i got a barb welded onto my tank for a couple of quid, good weld too!
Good stuff.
If it takes to the surface of the metal cleanly it's solid as fook.
Can be drilled, filed what ever.
Personally I'd choose welding for the flamer kit nut and wouldn't like to trust the chemical metal under pressure with fuel.
That could be a nasty fire!
07-10-2015 12:56 PM
