computer boffs
Old Mar 8, 2009 | 02:24 PM
st3v3's Avatar
st3v3
Default computer boffs
If my Mother board supports a cpu which runs with a Bus speed of 333 MHz then i put a new cpu which runs at a Bus speed of 400 MHz am i right in saying the new cpu will run absolutely ok but only at 333MHz?
cheers
steve.
Old Mar 8, 2009 | 02:52 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
as long as the architecture is the same and that you do not exceed the number of cores supported by the mobo the answer is yes.
Old Mar 8, 2009 | 02:54 PM
st3v3's Avatar
st3v3
How can i tell the differences between the numbe of cores and the architecture?
Old Mar 8, 2009 | 03:05 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
will run at the maximum capable speed of youre motherboard
Dont worry about architecture and cores. No need to.
Old Mar 8, 2009 | 03:19 PM
Turbocabbie
Top Cab !!
Why is it then if you plug a dual core processor into a early pcchips board supporting socket 939 single core processors, it does not work? - The socket is the same?
Old Mar 8, 2009 | 03:47 PM
st3v3's Avatar
st3v3
ok thanks
but it would be an xp 2200 cpu for a xp 3200 cpu so pretty much like for except for the bus speed, so i presume this would still be ok?
Old Mar 8, 2009 | 04:46 PM
macai's Avatar
macai
Evolution Chips Installer
Shouldn't be a problem
Old Mar 8, 2009 | 09:55 PM
Ebonycossie4x4
i meant dont worry about the cores in this instance as he has booted the pc therefore he knows that the core of the processor must match the motherboard as it has booted.
Sorry just felt that he didnt need confusing any more than neccesary thats all.
Old Mar 8, 2009 | 10:05 PM
Jim Galbally's Avatar
Jim Galbally
which mobo, there will be a list of supported CPUs somewhere for it. you'll probably want to do a BIOS update so it's got all the latest CPUID support
Old Mar 8, 2009 | 10:06 PM
Jim Galbally
i've just seen that first comment, "don't worry about the architecture"
Old Mar 8, 2009 | 10:14 PM
Stu.H's Avatar
Stu.H
+1
Old Mar 8, 2009 | 10:22 PM
st3v3's Avatar
st3v3
cheers all
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
