fiesta rs turbo boostin problem,????an help
rite av got a fiesta and iv just fitted a boost valve coz i couldnt get any more movment on the actuator an now av got 1.2 bar but it holds it for 2 seconds an drops to meby .6th of a bar an answers,cheers john
i take it when you say a boost valve you mean a bleed valve?
as a boost valve is just an adjustable fuel pressure reg
but it does sound like your actuators fooked or you have a wastegate problem
yer a bleed valve,,a tak it its most likely to be the actuator then coz thers defo ne leaks,,1 last thing y after a hard drive does the engine idle at bout 1000,-1200 rpm,cheers john
vdun01
Ford Fiesta
05-10-2017 08:14 AM
