standard esc cos charge cooler
Yes dave you should be ok, only problem you might have is if you are flat out for long time or tracking it you will heat up the coalant water higher which might cause you a problem, unless you have what spiky said but these cost as much as a 500 type ic so i would just change the ic and be done with it, because as we all know 350 bhp wont be enouth !!!!!
Can do you a Pace charge cooler upgrade kit for £350 normally £365+vat (runs a seperate rad etc for better cooling)....
see link below for details
http://www.paceproducts.co.uk/automotive-parts.shtml
You know that......lol, only cheap due to having 1 in stock as someone orderd it and never picked it up...
Cos500
16-09-2015 09:50 PM
