3dr ECU pins
3dr ECU pins
can they be accessed by removing the cover off the back of the plug as i need to take some measurements with the ecu plugged in?
PIN 1 (30-61A) Connection for ignition adjustment BROWN
PIN 1 (30-61B) Earth BROWN
PIN 2 Not Connected
PIN 3 ECU - CRANK SENSOR (31B-72) BROWN/RED
PIN 4 ECU - CRANK SENSOR (1-1A) GREEN/RED
PIN 5 (1-5) - Green / Yellow - Distributor (1-5)
PIN 6 Not Connected
PIN 7 Not Connected
PIN 8 Not Connected
PIN 9 Not Connected
PIN 10 BLUE - PIN85 POWER RELAY
PIN 11 - Manifold AIR TEMP SENSOR (31B-11C) BROWN/GREEN
PIN 11 ECU - MAP SENSOR (31B-11D)BROWN/GREEN (SHIELDED)
PIN 11 ECU - COOLANT TEMP SENSOR (31B-11C) BROWN/GREEN
PIN 11 ECU - THROTTLE POSITION SENSOR (31B-11A) BROWN/GREEN
PIN 12 (31B-35) BROWN/GREEN
PIN 13 Connection for ignition adjustment (15-10) BLACK/BLUE
PIN 14 Connection for ignition adjustment (15-9) BLACK/GREEN
PIN 15 ECU - MAP SENSOR (54-46) BLACK/RED (SHIELED)
PIN 16 ECU - AMAL VALVE (31B-68A)BROWN/GREEN
PIN 17 ECU - THROTTLE POSITION SENSOR (54-45) BLACK/YELLOW
PIN 18 ECU - Fuel Injector CYC 4 - (31B-43D) BROWN/WHITE
PIN 19 (31-61B) Earth BROWN
PIN 20 (30-42) RED PIN 87 POWER RELAY
PIN 21 Not Connected
PIN 22 Not Connected
PIN 23 (15-13) - Black / Red - Distributor (15-13)
PIN 24 IGNITION AMP (15-C)BLACK/RED
PIN 25 IGNITION AMP (15A)BLACK
PIN 26 Not Connected
PIN 27 Not Connected
PIN 28 BLUE/BLACK - PIN85 FUEL PUMP RELAY
PIN 29 ECU - COOLANT TEMP SENSOR (54-44) BLACK
PIN 30 ECU - MAP SENSOR (30-45)RED (SHIELDED)
PIN 30 ECU - THROTTLE POSITION SENSOR (30-45A) RED
PIN 31 - Manifold AIR TEMP SENSOR (30-46) RED
PIN 32 ECU - Fuel Injector CYC 2 - (31B-43B) BROWN/GREEN
PIN 33 ECU - Fuel Injector CYC 3 - (31B-43C) BROWN/BLACK
PIN 34 ECU IDLE SPEED CONTROL VALVE (31B-68CRG) GREEN/YELLOW
PIN 35 ECU - Fuel Injector CYC 1 - (31B-43A) BROWN/YELLOW)
PIN 2 Not Connected
PIN 6 Not Connected
PIN 7 Not Connected
PIN 8 Not Connected
PIN 9 Not Connected
muz
30-09-2015 08:29 AM
