Any PF programmers in? can i get a hand?
Hopefully somebody will know what I'm on about....
I'm trying to build a basic (windows) panel with two text entry fields. I'm trying to learn Groovy 1.6.0 and NetBeans is failing to compile this code and i think its to do with the open quotation mark in the two textfield statements, i cant take them out though because they are in the working examples I've been through from the developers website so they must work in the code, if they don't then I don't know what would
Here's my simple code......
import javax.swing.WindowConstants as WC
import groovy.swing.SwingBuilder
def swingB = new SwingBuilder()
def frame = swingB.frame(tittle:'Example01', location:[100,100],size:[800,800],
defaultCloseOperation:WC.EXIT_ON_CLOSE)
panel(border:titledBorder(title:'Name'))
label(text:'First name:')
textField(text:",columns:20)
label(text:'Last name:')
swingB.doLater{frame.visible = true}
Does anybody know why that causes an error?
Thanks in advance
Pete
Thanks in advance
Pete
Thanks Chris, I did have it in as a single quote but after your post changed it to two inverted comma's ('') and now this comes up
init:
deps-jar:
Trying to override old definition of task http://www.netbeans.org/ns/j2se-project/3:javac
Compiling 2 source files to C:\Documents and Settings\Owner\My Documents\NetBeansProjects\JavaApplication1\build\ classes
The option destdir cannot be set on the contained <javac> element. The option will be ignored
The option srcdir cannot be set on the contained <javac> element. The option will be ignored
The option includes cannot be set on the contained <javac> element. The option will be ignored
The option excludes cannot be set on the contained <javac> element. The option will be ignored
The option deprecation cannot be set on the contained <javac> element. The option will be ignored
The option includeantruntime cannot be set on the contained <javac> element. The option will be ignored
org.codehaus.groovy.control.MultipleCompilationErr orsException: startup failed, Invalid commandline usage for javac.
javac: invalid target release: ${javac.target}
Usage: javac <options> <source files>
use -help for a list of possible options
1 error
C:\Documents and Settings\Owner\My Documents\NetBeansProjects\JavaApplication1\nbproj ect\build-impl.xml:339: The following error occurred while executing this line:
C:\Documents and Settings\Owner\My Documents\NetBeansProjects\JavaApplication1\nbproj ect\groovy-build.xml:16: Compilation Failed
BUILD FAILED (total time: 1 second)
any ideas?
init:
deps-jar:
1 error
any ideas?
def frame = swingB.frame(>>>tittle<<<:'Example01', location:[100,100],size:[800,800],
shud be fixed, simple spelling mistake... been a while since i have coded though notice i have put three arrows eitherside of it the mistake
if i still had all the programs installed i would spend more time working out what's wrong but im afraid i dont.... plenty of help on google if you have a look though
Tried it again and getting this...
init:
deps-jar:
Compiling 3 source files to C:\Documents and Settings\Owner\My Documents\NetBeansProjects\JavaApplication1\build\ classes
org.codehaus.groovy.control.MultipleCompilationErr orsException: startup failed, C:\Documents and Settings\Owner\My Documents\NetBeansProjects\JavaApplication1\src\Gr oovyScript1.groovy: 12: expecting anything but ''\n''; got it anyway @ line 12, column 40.
label(text:",'First name:')
1 error
BUILD FAILED (total time: 0 seconds)
A bit dramatic eh?
init:
deps-jar:
1 error
A bit dramatic eh?
Livin' [H]ard & Fast
Thanks in advance
Pete
Thanks in advance
Pete
can you link me to the site your learning from.... might get back into solving this sort of stuff... working on summink now but i have no compilers to check it
got bored so had a little play (its been 2 years since ive touched any code so it may be rough and not what your after)
but this should do exactly what your after i reckon.... let me know?
SwingBuilder.build(){
frame(title:'Example01', location:[100,100], size:[800,800],
visible:true, defaultCloseOperation:WC.EXIT_ON_CLOSE){
gridLayout(cols: 2, rows:0)
label 'First name:'
input = textfield(columns:20, actionPerformed: {
output.text = input.text })
label = 'Last name:'
label 'First name:'
07-10-2015 12:56 PM
Adam Graham
06-09-2015 06:04 AM
