Twin Turbo cossie engine?
#161
Dont forget Mart was running an R+D 6 speed that helps the sprint times compared to a 5 speed syncro equipped car
#162
Agreed on the transmission, his new car doesnt seem able to match the acceleration times despite way more power!
#165
hmm i might have to ad that my car weighs 1430kg WITHOUT me in it and am running a fixit box with fucked up gearing.
1. 95km/h
2. arr. 150km/h
3. 195km/h
4. arr. 245km/h
5. 295km/h
And to be honest, that´s not a good gearing for ANYTHING
1. 95km/h
2. arr. 150km/h
3. 195km/h
4. arr. 245km/h
5. 295km/h
#166
#168
definately points to 600bhp+ then to get those sort of times!
#169
Yep..... 60kg heavier. I have not tried to match the old cars sprint figures yet, will have a go this year but there's adjustability now in the torque split so a bit of experimentation will be needed.
#170
1300kg is a good weight considering I reckon
Yeah I can imagine it taking more practice now.
On the T6 presumably you can map the split based on front and rear wheel speeds like you could on Autronic Sm4 ? So given a bit of programming you should be able to make it work very well consistantly by largely relying on the map?
#171
I thought everyone close to Martin knew the weights of his cars - perhaps you're just not in the loop any more?
#176
#177
Was very tempting! The gearbox has TOTALLY changed the car... its REALLY fierce now. Just always on the boil, and being on boost all the time because of the extra and shorter ratios meant that the whole car felt 'tighter' and more controllable if that makes sense?
