5th gear, focus rs, and rs turbo
#123
*** Sierra RS Custard ***
Valued at about a quarter million quid IIRC the one at luton.
I believe thats the 740bhp one with the carlton diesel block.
Was having a good look over it recently at a show if its the same one, it really is an amazing piece of engineering!
#130
The ladies love it French
I bet the people in the 5th Gear production office are pissing themselves with all this bickering going on.
New RS is nice though, snot green is not for me however.
#131
ST by Name and by Nature
Good to see both old cars head to head and the new Focus RS, but both items far too short, 5th gear then waste 10-15 mins with Tiff pratting about in a plane. I thought it was a CAR show!!!
#136
Super Moderator
Engine 0-60 Top Speed Power(BHP) Torque(lbft)
MKI Astra SR 1598cc 11.8s 104mph 88 @ 5800rpm 93 @ 3800rpm
MKI Astra GTE 1796cc 9.5s 116mph 113 @ 5800rpm 111 @ 4800rpm
MKII Astra GTE 1796cc 9.2s 118mph 112 @ 5600rpm 116 @ 3000rpm
MKII Astra GTE 1998cc 8.7s 127mph 122 @ 5600rpm 127 @ 2600rpm
MKII Astra GTE 16v 1998cc 7.4s 132mph 156 @ 6000rpm 150 @ 4800rpm
#137
Super Moderator
Engine
Type: CVH
Capacity: 1596cc
Bore/stroke: 79.96 mm x 79.52 mm
Compression ratio: 8.3:1
Max power: 132 bhp @ 6000 rpm
Max torque: 133 lbf.ft @ 3000 rpm
Cylinders: four, in-line
Cylinder head: alloy
Block: cast iron
Installation: front-mounted, transverse
Valve gear: two cylinders per head, operated by belt driven overhead camshaft
Induction: Garrett T3 turbo, intercooler, Bosch KE-jetronic fuel injection
Transmission
Type: front-wheel-drive
Gearbox: five-speed Ford manual with 218mm clutch, viscous limited slip differential
Internal ratios: 1st, 3.15:1; 2nd, 1.91:1; 3rd, 1.27:1; 4th, 0.95:1; 5th, 0.76:1
Final drive: 4.27:1
Suspension
Front: MacPherson struts, tie bar arrangement with separate 16mm anti-roll bar
Rear: independent with transverse trailing arms, coil springs, telescopic dampers and
12mm anti-roll bar
Steering
Type: variable-ratio rack-and-pinion
Brakes
System: vacuum servo-assisted dual circuit hydraulic
Front: 240mm ventilated discs
Rear: 203mm drums
Wheels & Tyres
Wheels: seven-spoke RS alloys, 6x15
Tyres: 195/50 VR15
Performance
Max speed: 132 mph
0-60 mph: 7.8 sec
Type: CVH
Capacity: 1596cc
Block: cast iron
Transmission
Final drive: 4.27:1
Suspension
12mm anti-roll bar
Steering
Brakes
Rear: 203mm drums
Wheels & Tyres
Tyres: 195/50 VR15
Performance
Max speed: 132 mph
0-60 mph: 7.8 sec
#138
FOR ANYONE WHO MISSED IT http://demand.five.tv/Episode.aspx?e...me=C5143730008
But if you are familiar with downloading from Usenet you can get it from here: http://binsearch.info/?q=S15E08&max=...age=50&server=
#145
Resident Wrestling Legend
having had a few mates who have the 16V gte and a few mates who had rst's, in a straight line dash it was pretty much even between both cars
when it came to handling, the rst was marginally better
when it came to stopping the rst was a lot better
the astra was much better on fuel though and as a normal "car" as opposed to the rst
then they were both modded and the sheer abundance of bits for the rst made it a much better car
this is all harking back 10-12 years ago and we were just your run of the mill drivers who didn't claim to be better than anyone else (other than the guy in the 306D that said he was quicker than anything else on the planet, even though his best 0-60 time was just under 20 seconds )
no one could keep up with a stage 1 4be saph though
#146
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
