AP organic clutch disk problem
Have put AP clutch disk for YB with cover plate from 2.9 Granada(Scorpio) and it slip like cow on the ice Before I have used clutch kit for 2.9 on my cos it was fine a lot of time. Can be a thickness of AP disk a reason? It a little thicker then 2.9 disk.
i'm not sure; i have tried searching but cannot find the answer
you can email AP directly roadtech@apracing.co.uk
I need to know the distance of cover plate(for original AP clutch disk) between mounting surface to flywheel and mounting surface to clutch disk. If I will know this distance I can put washers between my cover plate and flywheel to solve my problem.
Please help, I need this distance.
