greys ??????????
Old Feb 15, 2009 | 01:31 PM
COLEYST200's Avatar
COLEYST200
Default greys ??????????
a mate of mine how has a escort cosworth wonts to no if he can run these in his car we no the car will have to set up for them but we just need to no if they are ok for the car.
THANKS FOR ANY HELP
http://cgi.ebay.co.uk/Set-of-4-Weber...1%7C240%3A1318
Old Feb 15, 2009 | 01:43 PM
LHD220Turbo's Avatar
LHD220Turbo
THANKS FOR ANY HELP
yeah but you'll need a fitting kit
Old Feb 15, 2009 | 01:46 PM
As above they 0280 150 403 will fit with fitting kit.
Old Feb 15, 2009 | 02:08 PM
big_wig_074's Avatar
big_wig_074
you dont need a fitting kit at all,i didnt use one and loads of other people dont either,yep these will fit your car no worries
Old Feb 15, 2009 | 02:16 PM
mechanic28's Avatar
mechanic28
???? i thought you had too use the fitting kit?the same as the light blues!?
Old Feb 15, 2009 | 02:34 PM
COLEYST200's Avatar
COLEYST200
SO wot you are saying is they will work and all he has got to pay out is 86 pound instead of 200/250 pound
Old Feb 15, 2009 | 02:39 PM
KSA-Cossie's Avatar
KSA-Cossie
Why bother,i'd fit siemens blacks instead.
Old Feb 15, 2009 | 03:11 PM
Aaroncast's Avatar
Aaroncast
Fitting kit or no fitting kit???
As indecisive as ever--lol
Old Feb 15, 2009 | 03:17 PM
westus1's Avatar
westus1
they can be used with no fitting kit
but when bought new then you should use 1
its just the end caps and the rubber o-rings in the fitting kit
if they're 2nd hand(i imagine they are at that price) they will prob go straight in
as long as there is o-rings fitted they will work
Old Feb 15, 2009 | 03:21 PM
As supplied by BOSCH they won't fit, thus someone, you or the person before neds to fit a kit, that is basically a collar that holds and additional seal on the top, without this bit not a snowballs chance in hell of stopping 3 bar spraying everywhere.
Depends whether the ones you want have it or not, I cut the very end of the cap off too, when using these, leaving just the other part on the injector.
Old Feb 15, 2009 | 03:28 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
As Tabs has said, cut the end off the cap for a better spray pattern.
Steve
Old Feb 15, 2009 | 03:39 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
this is why greys get a bad name and flood the engine.............yes ur ment to have a fitting kit....(only £30 or something)
Old Feb 15, 2009 | 04:48 PM
Bullett's Avatar
Bullett
mines on greys. ive always heard they bore wash.i want to change at some point.
Old Feb 15, 2009 | 04:50 PM
LHD220Turbo
that's a bit of a myth to be honest; i read a thread on it which stu commented on, he was saying they can be mapped the same as any other injector - i'll see if i can find the thread
but yeah; i'd have siemens blacks over any bosch
i had 55lb in mine
Old Feb 15, 2009 | 04:53 PM
Alvyn's Avatar
Alvyn
If that's the case the cars been badly mapped or poorly set up m8!
Old Feb 15, 2009 | 05:05 PM
BRAMMER's Avatar
BRAMMER
Just fitted greys in mine yesterday and i can't see how you could run without the kits (which you can buy from ebay for £16)
Old Feb 15, 2009 | 05:17 PM
Moonstone Steve.
I have greys which i bought second hand, i had Phil check and clean them and then fitted them with no trouble, what do you get in the fitting kit thats needed as i was told you dont need the kit.
Steve
Old Feb 15, 2009 | 05:24 PM
Alvyn's Avatar
Alvyn
Steve
when you buy Bosch 0280 150 403 injectors NEW they need a fitting kit which allows them to fit the cossie fuel rail(without the kit they WILL NOT fit)
those in the ebay auction aint Bosch 403's!
Old Feb 15, 2009 | 05:34 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
goodluck getting software to run them if they are not normal spec
Nov 1, 2015 06:53 PM
Fil
Sep 30, 2015 12:08 PM
neilrev
Sep 24, 2015 04:31 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
