Best way of painting over gloss?
Doing the hallway, its been glossed 8mths ago, but weve had dado fitted so it now all needs redoing as its obviously faded already.
BUT i want to do it in satin finish as i hate the shine of gloss and how quickly it yellows, so my question is what do i need to do to prepare the surfaces to be painted? There are no doors as theyre all dipped and waxed, just the door frames and skirting boards, which is a grand total of 8 doors and about 28mtrs of skirting
Going to get paint tonight but want to get it prepped before weekend ready for painting
Thanks
Sarah
Thanks
Sarah
my dad tried stripping it a few years back, did about 2mtrs then gave up, plus the skirting is really dark wood and the doors are a lovely colour so wouldnt look right, i dont want to spend 4 weeks stripping to paint over it again
Is it just a case of giving it a good rub down and hey presto? got some of that sandpaper already
When I done my house, I got the old fella to do it as painting & decorating was his business. I believe he used a small sander to take the paint back, undercoated, and then painted again (gloss). Now I know he used good paint quality paint brushes as not to keep picking hairs out of the paint and used a non drip gloss.
Do not use a drill with a sanding disc on whatever you do!
Its defo better to put a undercoat on first, not for as captain says above " stopping reactions", but as to give it more body and it will adhere better to the flattened gloss.
So in order
Sand woodwork down with 180, i prefer grey paper
Dust it down
Wipe woodwork down with a rag and white spirit to remove any grease/oil
Apply one undercoat
Apply topcoat of either satin or eggshell ( eggshell has a bit more sheen to it and makes it a bit more wipeable)
So in order
Dust it down
Apply one undercoat
the correct finish for satinwood is two top coats of satin
just give it a rub down dust it off and wipe it with a lint free rag with some spirit on
wait ten minutes and away you go
if the gloss is solid you will get a far better finish with two coats of satin than one undercoat and one satin
i am a decorator as well 24 years in the trade
http://www.icipaints.co.uk/products/..._satinwood.jsp
in all the sites ive worked on in the last 20 years ive never seen painters with anything finer that 120. the few that do actually rub down mainly use 100 that i see. usually the white squares for sanding down the ames taping.
even when i was doing french polishing 240 was the general use stuff on the bars we were making/polishing.
you must be one of the fancy ones that hang paper as well as you call yourself a decorator and not just a painter.
Thats if his gloss is solid, what me and you can do is different to what a DIY'er can do
Plus i still stand by putting an undercoat on as it adheres much better to the flattened gloss. most of the jobs we come across where the paint is flaking in thin layers is because its just been topped and not undercoated in the first place along with not being prepped correctley in the first place.
But hey you have been doing it 2 years more than me, lol
Yes i do hang paper and do all the special finishes, 80 grit is good for really old woodwork yes, but is a bit harsh for finishing work
120 grey or 180 grey ( as i prefer for gloss ) is much better
the grey im on about is the same white you are on about.
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
