General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Went a bought some braided brake hose today and fittings, took the old ford rubber flexi with me and showed the bloke he said its 3/8 i need so thats what i got, come home made them all up and when fitting to the car and connecting to the original ford females its not pulling up straight and leaking, also feels wobbly when screwing the fittings into the callipers, has he given me the wrong thread or size, ive looked about and seen a comment that someone made saying ford rs turbo oe stuff is 10x1, so is this what i need ??
as the m10's are cheapjust change the ends (assuming you have customable brake lines)
yeah i made them up myslef, the fittings are similar to goodridge fuel hose with aeroquip fittings, just wanted to know that the problem is the fittings, hopefully should be 10x1 rather than 3/8, am i right in thinking 10x1 is slightly bigger
its actually for a escort rst s2, running cossie 4 pots on the front and cossie 2wd rears, the problem is with the threads connecting to the original metal brake pipe fittings i think i need 10x1 rather than the 3/8 stuff hes given me, doesnt pull up right and is leaking, any info much appreciated
Cheers mate this must be where the problem lies, just measured the thread of the 3/8 fitting with some digital callipers and it was 9.30mm and the original ford stuff measures 9.80mm so 10x1 has a slightly bigger diamater then
