Silver top with FRS rods and pistons?
![Question](https://passionford.com/forum/images/icons/icon5.gif)
Thinking of buying a set of FRS rod and pistons to go with my 2.0ltr silver top.
I assume I am right in the fact the silver top and black top 2.0litre are 84.8mm bore? So if I wanted to use the piston/rod package this would be ok providing my engine is in good order and I use new rings?
The Only problem I can forth see is that the cylinder head has a different cc and thus change the compression ratio.
Does anyone have any other stats for me to help work this out.
Any help is appreciated.
Mart
Mart
hmmm..
Looking better all the time. The rest of my spec is as follows:
FRST OFAB management
Ian Howell/ Ahmed Bayjoo superchip
2.5bar Cosworth map sensor
IW30 330cc Webber injector's
ERST exhaust manifold modified for Zetec head
2WD Cosworth T3 turbo
130ps inlet manifold with end-feed injector conversion using a modified focus 1.8 fuel rail and FRST fuel regulator and remote ISCV
Mondeo 136ps throttle body
Hopefully be able to run 1 bar+ and see some good results for my MK2 Fiesta
Yeah I know what you mean but where I stand at the moment I dont know if if I will sleeves to go with the arias stuff as it is such a big bore and it will cost me Ł200 for the machine work.
If I go the FRS route then I can re-hone myself and just build it up as is now.
Decisions decisions
Decisions decisions
![LOL](https://passionford.com/forum/images/smilies/icon_lol.gif)
Not wanting to argue etc.. but are you sure they are 87.5, not 86.5? that sounds like a hell of a re-bore and wouldn't leave much meat on the bore
orion=mini saff
took my zetec block and pistons and my engine chap is gonna do the measurments for me to see if the bores are to worn, but he can get new 2 litre blocks,so be handy!
JK12
33
26-04-2021 12:09 PM
