Gearing advice
Gearing advice
What ratio diff would be best suited to run with a T56 gearbox with the following ratios?
I have calculated the road speed in gear for five alternate crown wheel and pinions @ peak power
Engine spec is decatted LS9 so approx 650-700bhp with 600+ftlb from 2500rpm to redline
3.55
1st Gear Ratio 2.97:1 48.1mph
2nd Gear Ratio 2.07:1 69.0mph
3rd Gear Ratio 1.43:1 99.9mph
4th Gear Ratio 1.00:1 142.9mph
5th Gear Ratio 0.71:1 201.3mph
6th Gear Ratio 0.57:1 250.7mph
3.77
1st Gear Ratio 2.97:1 45.3mph
2nd Gear Ratio 2.07:1 65.0mph
3rd Gear Ratio 1.43:1 94.1mph
4th Gear Ratio 1.00:1 137.1mph
5th Gear Ratio 0.71:1 193.1mph
6th Gear Ratio 0.57:1 240.5mph
3.9
1st Gear Ratio 2.97:1 43.8mph
2nd Gear Ratio 2.07:1 62.8mph
3rd Gear Ratio 1.43:1 91.0mph
4th Gear Ratio 1.00:1 130.1mph
5th Gear Ratio 0.71:1 183.2mph
6th Gear Ratio 0.57:1 228.2mph
4.1
1st Gear Ratio 2.97:1 41.7mph
2nd Gear Ratio 2.07:1 59.8mph
3rd Gear Ratio 1.43:1 86.5mph
4th Gear Ratio 1.00:1 123.7mph
5th Gear Ratio 0.71:1 174.3mph
6th Gear Ratio 0.57:1 217.1mph
4.4
1st Gear Ratio 2.97:1 38.8mph
2nd Gear Ratio 2.07:1 55.7mph
3rd Gear Ratio 1.43:1 80.6mph
4th Gear Ratio 1.00:1 115.3mph
5th Gear Ratio 0.71:1 162.4mph
6th Gear Ratio 0.57:1 202.3mph
3.55
3.77
3.9
4.1
4.4
what do you want acceleration or top end? what car is it going in? do you want 6th as a really low revving cruise gear or as another gear the engine will pull? I would say anything under 3.9 will be useless, 3.9 will be a long geared car, and you will prob end up going for the 4.4, or the 4.1 at a push.
I'd love to join the 200 club but 200mph in 4th would require a 2.something diff. Im thinking either a 4.1 or a 3.55 but wanted some opinions before ordering the cwp.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
