alternator drop bracket
Old Feb 4, 2009 | 05:04 PM
westus1's Avatar
westus1
Default alternator drop bracket
i dont want to sound like a right mongo but i've got a alt drop bracket to fit to an escort after fitting a big turbo,
i've got the bracket but cant for the life of me figure out how to fit it, i cant get anything to line up, either on the alt bracket or the block,
is there differant brackets for differant types or am i missing something
any advice or pics please would be great as i'm stumped
sorry forgot to say its running the twin v belt set up from a saphy not usual escort ribbed belt
Old Feb 4, 2009 | 05:08 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
what side is your ps pump on?
they should just move the lower mounting bracket down,
Old Feb 4, 2009 | 06:05 PM
RobS's Avatar
RobS
i know i had to cut a little lump off my 200 block to get mine to fit on my 3dr.
Old Feb 4, 2009 | 06:07 PM
Paul_RS's Avatar
Paul_RS
The drop braket only works on 2wd and early 4x4 cars where the PS pump is under the inlet manifold. The later 4x4's and Escorts have everything under the exhaust manifold and its all mounted on one big bracket. The drop bracket doesn't fit this big bracket as far as i'm aware? Unless you've changed that to a 2wd version too?
JTECH James
Passion for Fords!
yeah you do, the hoop at the bottom
Old Feb 4, 2009 | 10:17 PM
westus1's Avatar
westus1
its early 4x4 saph set up,
pas pump is under inlet manifold,
its just that i cant even get the alt monting bracket to line uo with the holes on the drop bracket,
so i take it that i've got to cut off the lug thats in the way at the bottom of the block
Old Feb 5, 2009 | 09:32 AM
JTECH James
Passion for Fords!
yeah, cut it off
Old Feb 5, 2009 | 09:38 AM
carlo's Avatar
carlo
I had the same prob last week ended up not fitting the thing spent about a hour fucking about with it.phoned andy g & he said the block needed cut.
Old May 9, 2009 | 06:10 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
anyone know what the lug at the bottom of the block is for that blocks the installation of the drop bracket ?
ta
Old May 10, 2009 | 11:10 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
anyone??
Old May 10, 2009 | 02:18 PM
2001ode's Avatar
2001ode
ta
Hi,
I suppose it is for machine transfer manufacturing.
To obtain a point reference positioning for block at the beginning of process.
Regards.
Claude
Old May 11, 2009 | 06:28 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
Originally Posted by 2001ode
Hi,
Regards.
Claude
cheers,nowt important then as i chopped it off yesterday
jonfoc
16
Sep 11, 2018 05:35 PM
155lee
Oct 27, 2015 04:55 AM
Marv888
Sep 26, 2015 03:44 PM
