Turbo technics T38 - which manifold?
With different cams, ported head, low comp is the std 4wd ex manifold ok or must I use a 2wd one?
Would depend on where you want to make the power i would think a 4wd manifold will loose you a bit of power at the top end but give more torque lower down , a 2wd will give you more power higher up the revs. If your going for under 450 bhp you should be fine with the 4wd manifold.
JK12
33
26-04-2021 12:09 PM
