recomendations for live map/ r road set up
for a rwd saph stage 1
currently misfiring changed plugs dis cap/rotor arm
got a gp a coil to put on also been told to get bosch 044 fuel pump cause stil runs original one
any recomendations are much appreciated
You dont really need a remap for a stage 1 in my opinion.
If you really feel you want one then MSD or NMS as said above
The 044 fuel pump is an overkill and the standard pump is more than enough for stage 1 providing the wiring and pump itself are in good condition.
Having said that, replacing it if you can afford to do it is a good move.
Does it only miss fire on boost or hard acceleration ?
When it does miss fire, does the rev count stay smooth reading or does it jump about ?
If yes to both questions above, its most likely the plug gaps are too big or the wrong plugs.
Try gaps of 0.5mm as a test.
If the rev count jumps around, you probably have a crank sensor fault.
Simon
Simon
what plugs do you use and what are they gapped at
standard fuel pump is fine at your power level - just make sure its rewired for a direct feed from the battery (very very important!)
When it does missmire, does the rev count stay smooth reading or does it jump about ?
Simon
Simon
saff is working!!!...atm
remember thinking....why cant my stg3 (t3 greens) do out with a stg1 saff..(both 4x4)......thats the difference between a chip and a live map..........long live the live map
nice one chaps for feedback
i take it a live map is loads more expensive than rolling road session and i wouldnt mind stage 3 ing it at a later date just want it to run well have my fun out of for a few months ie learn to drive it properly first lol
when you want to go stage 3, providing your spec is straight forward and nothing wild - get a decent off the shelf chip from MSD (motosport developments) and take it too MAD in berskshire - job done
Escortdriver1
01-11-2015 07:55 PM
Marc sierra
12
30-08-2015 10:38 AM
