Small turbo cossie
Head is slightly different, oil pump has no spray bar, the block has WRC spray jets as std. There is a much smaller/No (can't remember which) core plug in the back of the block, and there is a crank windage tray instead of sump baffles. Inlet and exhaust manifolds are different.
erm, day to day, one im lookin at is ash black, 71tho never been rebuilt so gonna leave it standard 4 now. Check this link put a pic of it.
https://passionford.com/forum/showth...89#post3920689
-Can i get 330bhp?
-Hows the boost controlled on these?
-wat injecter setup?
-First cossy im goin to look at, wat i wanna look out 4????
im only used to 2wd cossy, had 1 for 6 years.
Big Thank you 4 the Help
See below .
-Can i get 330bhp? Not on the standard turbo / injectors / fuel pump / FPR etc
-Hows the boost controlled on these? ECU amd Electron valve
-wat injecter setup? High impedence equivalent to standard Cosworth injectors.
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
