WHO and how much to fit erst gearbox in Manchester???????
Piece of piss.
From memory.
Jack car, support on axle stands.
Support engine on jack.
Remove anti roll bar
remove engine cradle 5 bolts + 2 for engine mounts
remove starter motor 3 bolts
pull drive shafts out- i just pulled the wheels and mine popped out... ( might need to undo the bottom arms too )
remove the ancillaries from the engine bay above gearbox and disconnect the clutch cable quite easy
remove speedo drive cable- hand twists
Remove earth straps
7 or 9 bolts remain that bolt the bell housing to the engine
Pull gearbox off and check you've removed everything
drop it off the end of the shaft- watch out its quite cumbersome and heavy.
NB- this assumes no ABS- if the ABS is still fitted, its an ideal opp to fuck it off- but that involves more work, either way if the ABS is on there its more difficult.
Fitting is the reverse of removal... ha ha
If you've got good enough help should be an out / in job within a few hours and a few cups of tea.
Jake
From memory.
Remove earth straps
Jake
YES I KNOW I CANT SPELL
i will offer my services pal... but would much prefer to do it at my gaff... due to i know what tools i have and i have a nice little compressor and air tools lol... could even rope the missis in to keep the brews comeing lol
if its just wineing im sure you'll be able to drive to the other side of Bury with it...
just drop me a pm and we can see whens good, or msn me M19ROO@hotmail.co.uk or even facebook lol Richard Edwards (pic of me and my 8month old son with big cheesy grins for the camera)
new work bench built
check out the cd player mounted in the bench frame
plenty of room around the beast
more painting
tidying up after painting
tomo ya big homo this is a thread about a gearbox yet yu manage to fudge pics of ya garage on here!!!!
Right so when you get box and all bits, i say the PMT get round and we get this box on super shaprish! lets even do 2 as i need my box puttin on lol!
(tomo do you still have that block in ya garage with the cps hole?)
I rekon ill have the box for next weekend...not sure what oil to get yet and I also need a cv boot as its split :@....ul have to let me know ŁŁ and do u want my g'box?
nah mate you can keep it i'll have a spare anyways..
halfords will sell gearbox oil, listed in the little flippy book thing on the shelfs, and id image you can get boot from them too, or just use someone like Andrew Page.
