long studds
25-01-2009, 08:58 PM
long studds
has any one had problems with them ie water coming past the o ring making the water mix with the oil
25-01-2009, 09:00 PM
Passion for Fords!
no, but i always use a dolop of silicone on the o ring, to seal, and stop them pinching when torqued up
25-01-2009, 09:04 PM
i didnt do that but i have now and with another new wrc gasket
25-01-2009, 09:06 PM
Passion for Fords!
what longstuds? the reyland ones?
25-01-2009, 09:08 PM
25-01-2009, 09:10 PM
1st to 200 without NOS
Quote:
Originally Posted by
cossiedave
No never but as Jtech mentioned I always use a little silicone sealant too.
the older style 1's have started to get a reputation for failing nowadays
but the new reyland 1's are supposed to be modified and solve the problem
i thought it was cause they were causing blocks to crack but that might not be the case
Passion for Fords!
well they should be spot on,
i use reyland studs, they are very good, and use a smaller nut, which is easier to get a socket on...
did you have your block decked?
25-01-2009, 09:17 PM
its been decked m8 along with the head as its all been apart didnt have any problems befor may be i used sillcon befor and not this time
25-01-2009, 09:21 PM
Passion for Fords!
hope thats it then mate
25-01-2009, 09:23 PM
JTECHSAFF
so do i as at Ł140 a time for gaskets it getting to dear now
25-01-2009, 09:26 PM
Passion for Fords!
you can reuse them,
i used mine twice with no issues.
25-01-2009, 09:29 PM
not going to chance it m8 matt is sending one out tomorrow for me even tho its only been started up
25-01-2009, 09:30 PM
do you use weld seal or just put it on dry m8
25-01-2009, 09:32 PM
Passion for Fords!
just dry mate, never had any issues at all with mine even the second time.
mjonathan24
29-10-2015 10:39 PM
A.t.p
23-10-2015 07:54 PM
sridgett
01-10-2015 07:30 PM
Fudgey
21
30-09-2015 06:19 PM
Fil
30-09-2015 12:08 PM
