Phase sensor
Old Jan 24, 2009 | 03:00 PM
manoj's Avatar
manoj
Default Phase sensor
Hi,
Just changed my Phase sensor on my Cosworth Dizzy, I have connected the Red Wire to the + on the Dizzy Connector. Is this correct.?
The old phase was completely knackered and had no shielding on the wires.
thanks,
Manoj
Old Jan 24, 2009 | 03:06 PM
ECU Monitor Enthusiast
Thats ok
Old Jan 24, 2009 | 04:39 PM
Correct.
Old Jan 25, 2009 | 10:02 AM
Do the new phase sensor wires last a bit longer than the old sensors.Just out of interest i take it when these wires on old sensors start to crack and if the wires touch i take it that it will cause running problems.
Old Jan 25, 2009 | 10:30 AM
Yes will cause problems, yes the new ones have MUCH better insulation that lasts.
I THINK it only senses the phase position for starting but once running could be disconnected, but if it can't tell phase it will overfuel enormously.
Old Jan 25, 2009 | 11:48 AM
Yes and no !
It depends on what ecu and how the sesnor fails while the engine is running.
Way too many combinations for a sunday with a hangover to explain.
Old Jan 25, 2009 | 12:19 PM
You people know your stuff and are a credit to this site.
Old Jan 25, 2009 | 06:08 PM
I don't know if I ever did it with my w/m ecu but with my present one, it's totally ok, and continues to run perfect even when disconnected and left like that until you start again.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
