has any one tried l6 coz management on a pinto turbo
The last one I encountered was a capri. It was built up using a spare complete 205 YB short motor that I donated, a big valve pinto head and megasquirt along with a T4 turbo.
They aint plug-and-play...they are plug-and-arse-about, lots.
Whilst in france the capri came on boost then decided it didnt like its own propshaft so it spat it out Which I and my mate (pictured) on foot
have done all this dizzy cranck sensor it will run but wont boost without moving the crank sensor it just holds back BUT RUNS WELL WITH CRANK SENSOR MOVED A BIT stu says it must be my set up but cant see how HELP 07724045733 AM GOING MAD
You need to check with a timing light the ignition pulse is correct.
Start with idle speed
If all that checks out then it needs mapping, you will need to consult an expert for that.
JK12
33
26-04-2021 12:09 PM
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
nicos#29
17
07-09-2015 05:32 AM
