does an engine
Old Jan 23, 2009 | 03:55 PM
slim20012's Avatar
slim20012
Default does an engine
need to stay above a certain amount of revs ? say 2500 to put charge in a battery
as my battery was dead and i was just letting it tick over and my old man was sayin i need to keep the revs up or it wont charge it
Old Jan 23, 2009 | 04:04 PM
Thefuturesbright's Avatar
Thefuturesbright
JAFSPORT
normally when ive jump started a car ive held the revs up to help it out, the quicker the alternator is going the more current induced.
Old Jan 23, 2009 | 04:07 PM
woodz77's Avatar
woodz77
ive always been told , yes , mate . when ticking over the volts is 12ish and when running the car on a journey its nearer 14 ? so it wont charge hardly at all if just sitting on the spot . i aint no mechanic but ive been told this a couple of times . best to jump it and then take it on a ride? pop to Mcdonalds and back in the Galleria
Old Jan 23, 2009 | 04:20 PM
slim20012's Avatar
slim20012
bet go take that shut the fuck up back and get on my kness lol
i wouldtake for a spin but iv got no tax so will have to sit there till payday
cheers all
Old Jan 23, 2009 | 04:29 PM
C4llyT's Avatar
C4llyT
Plenty of volts at tickover, often seen around 14 on many different cars.
I was told the same however, so don't know if it's the amps or something that could cause it if true.
Old Jan 23, 2009 | 04:30 PM
cabriolet's Avatar
cabriolet
i repair them for a living your dads right fella
Gazzonator's Avatar
Gazzonator
Gary Krishna
You should have between 13.5 - 14.5 volts at idle imo.
You shouldn't have to keep the engine running at 2000 rpm for the battery to charge.
If the alternator is only putting out 12v ish at idle (assuming the idle is correct and not too low) i would say something isnt quite right.
Old Jan 23, 2009 | 04:32 PM
C4llyT's Avatar
C4llyT
So is it not volts that tells you?
Never noticed a difference between idle and fast idle for volts, without loading the electrics up.
Old Jan 23, 2009 | 04:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yup thats right!
Old Jan 23, 2009 | 04:59 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
anyone want to know how alternators work?
i did a write up on them, il find the link if you want....
Old Jan 23, 2009 | 05:02 PM
cabriolet's Avatar
cabriolet
not necessarily on a fully charged battery it changes under load off load change the parameters and voltage and amperage changes
Old Jan 23, 2009 | 05:06 PM
SiZT's Avatar
SiZT
for a lot of cars its 13.6 at idle and 14.2 at half the maximum engine revs
Old Jan 23, 2009 | 05:07 PM
Patto's Avatar
Patto
Would be a good read if you have the link?
Old Jan 23, 2009 | 05:08 PM
JTECH James
Passion for Fords!
ok brb...
Old Jan 23, 2009 | 05:13 PM
JTECH James
Passion for Fords!
here you go.
https://passionford.com/forum/showth...74#post3897574
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
