scorpio problems
Old Jan 21, 2009 | 06:47 PM
spliffy57's Avatar
spliffy57
taz
Cool scorpio problems
hi can anyone help i have got a 1992 granada/scorpio j reg 2ltr dohc with fuse box problems without putting key in ignition everything works wipers/windows/heater indicators etc i think it is the fuse box took out all fuses and relays blow dried with hair dryer for an hour today but no joy. car starts and runs ok also abs light comes on an off. its all related to fuse box as we had a lot of rain this weekend it was ok before i just need to know how to remove fuse box from car. manual does not cover this . bought the car last nov for £60.00 as it was really filthy with one months mot three months tax. lady i bought from wanted £80.00 i stuck a new set of back brake pads front gaiters and two new track rod ends sailed through mot body work has no rust even air con still works this is the fifth granny ive had over the years may not be the last thanks for reading any help will be very welcome
Old Jan 21, 2009 | 07:14 PM
mick's Avatar
mick
i hope this is the right link.. i've got the same job to do on my 24v one...
http://granada-and-scorpio-online.co...&threadid=2499
Old Jan 21, 2009 | 07:30 PM
dojj's Avatar
dojj
Resident Wrestling Legend
remove fusebox
strip it out
clean it up
replace
working
then find the covers that were available for the recall for water ingress into the fuseboxes
one is plastic and goes over the battery etc
the others are rubbery and plastic seperate that go over the drivers side ones that does the lights etc
easy enough to pop out
Old Jan 21, 2009 | 07:32 PM
Graham S1's Avatar
Graham S1
Aha, my specialist subject. Fookin things....
It's probably corroded to fook inside. It's a bastard to get out too. You have to lay in the footwell, and stick your arm right up into the top corner of the dash.
I took mine apart, and took it to an anodising place, where they stripped all the crap off for about £15 and put it back together myself. Or you could get a replacement, but if 2nd hand it's likely to have similar problems.
WHY do they put it where most of the water collects.
Yeah, if your small enough to stand in the footwell. Or use a crowbar and sod the nuts.
Old Jan 21, 2009 | 08:03 PM
spliffy57's Avatar
spliffy57
taz
thanks guys will strip it out this weekend and let you know what happens
Old Jan 21, 2009 | 09:09 PM
dojj's Avatar
dojj
the drivers side one is easy as pie, the other side is a little less easy
Old Jan 21, 2009 | 10:08 PM
mick's Avatar
mick
remove fusebox
so i take it you'll do mine for me.......
Old Jan 22, 2009 | 04:59 AM
dojj's Avatar
dojj
possibly
Old Jan 22, 2009 | 06:44 AM
iansoutham's Avatar
iansoutham
OCD Victim
certainly
Good lad Dojj
Old Jan 22, 2009 | 09:21 PM
dojj's Avatar
dojj
you cheeky coonts
it's the driver side one he's fucked up
Ian1964
12
Jan 26, 2021 11:57 AM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
