Help please ,, Fuel pumps / swirl pots etc
Im trying to fit my fuel pumps etc in the 3 door and need advice ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
As you can see by the piccs , the bottom 2 pumps are lift pumps and will be pulling from the tank ( not fitted yet ) and feed the swirl pot .
From the bottom of the swirl pot is the outlet that will feed the top 2 pumps that go to the filter and then to the engine
I have a return from the engine to the top of the fuel tank , and also a return at the top of the swirl pot to the fuel tank
What i want to know is if i have done anything wrong or im missing somthing
Paul
![](http://i2.photobucket.com/albums/y34/north-yorks-rs-spares/BTTFuelpumps001.jpg)
Paul
![](http://i2.photobucket.com/albums/y34/north-yorks-rs-spares/BTTFuelpumps002.jpg)
escort mk4 cossy 4x4
the first 2 pumps look like cos items,and are not lift pumps. ie you will have to gravity feed them.
wont that totally defeat the object of having a swirl pot?
So what am i missing ?? this is what im asking
I know your saying that the tank can get low and starve the pumps that fill the swirl pot , But then thats why the swirl pot is there as this SHOULD hold enough fuel till the pumps grab more fuel and refill the swirl pot
They are all cossie pumps , and the swirl pot is only there as there isnt one in the tank
So what am i missing ?? this is what im asking![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Im running a cossie pump as a lift pump but tbh Ive got it in its standard possition coming from a standard tank that now has no internal swirl pot. Seems fine so far. Do you really need two cossie pumps as lift pumps though? As said previously by someone, you'd be better returning from the rail to the swirl tanks top side pipe then use the very top pipe as an outlet to the tank.
All i thought mate was if 2 pumps are pulling from the swirl pot 2 should fill it
Plus it looks sexy , and all 4 pumps can be turned on and off individually so i can turn one lift pump off i its not required , and this also gives a spare if one should fail
![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
Passion for Fords!
well thats the reason many people dont run them like that... as the fuel just keeps warm, and gets warmer each time it circulates. returning to the tank gives it much longer to cool, and it mixes back with cool fuel.
if you jet(restrict) the return from the pot to the tank, it keeps the swirl pot under pressure. i think this is the way to run them, with a 3mm jet in the return line.
im no expert, i would recomend speaking to martin at reyland, or tony from turbosystems or stu at msd
no, the swirl pot will run dry seconds after the 1st pumps stop getting fuel,plus cos pumps are lubricated by fuel passing through them,so if they run dry,they will fail very quickly.
So what your saying is ,,Return to the tank not the s/pot , and the return / overflow from the s/pot to the tank should be a small pipe ?
this is exactly how i thought hence the smaller return on top of the s/pot
The tank i will use will have a small box ( about 6" x 6" x 6" ) that will sit through a hole in the boot floor that will be like a pot , this will have the fitting for the fuel lines that will supply the 2 " lift pumps "
I will need to drill 2 holes in the alloy wheel well to let the lines through
JK12
33
26-04-2021 12:09 PM
Minirotty
11
15-09-2015 10:16 PM
