36-1 kit for MFI ERST???
A mate of mine popped by with his new ERST that he wants to convert to EFI.
Rather than go to the hasssle of mounting a trigger and making a sensor mount for him is there a kit on the market i can gt him to buy?
Crank position sensor you talkin about? Just use fiesta turbo flywheel as this has the crank tooth pattern on the back and will work with the fiesta crank position sensor. However the block may not have the mounting hole for the sensor to bolt into if it's an early car.
Tabetha there is no bracket on an MFI CVH.
What i was asking is if there is a kit to save me having to mount a trigger wheel on the pulley myself and fabricate a cps bracket.
I'm flat out and was wondering if there was a kit that would save me some work.
But it seems there isn't.
Changing flywheel is not an option.
If the ecu is a good one you can program number of teeth etc.......
Fit an RST dizzi that has had its trigger vanes modified by adding extra slots in a required pattern.
For example, 7 slots in total with one missing. or add an extra slot to the existing 4.
If the ecu is a good one then it should do it no problem
Eruption 101.3fm
Garage19 there is a kit available and has been available for about 7 years from www.oddkiddcreations.co.uk
07984 071 567
ring jano and tell him Danny told you to call him, ask for a decent price he will sort you out.
Mc5506
05-10-2015 09:57 PM
