406 pugeot heater
406 pugeot heater
can someone help with the heaters on 406 executive td the heaters are luke warm
when its on auto setting .but when you put the blower on it just blows out cold air
have change the thermostat and gave the system a good bleed but cant get it hot
any ideas,it also got air con thanks
Is it the diesel one? If so, is it the Hdi or XUD engine?
On the XU, there is a top bleed nipple just behind the intercooler on the drivers side if you didnt already find it.
Im at the same point with my runner, need to run a hose through the heater matrix and have another try at bleeding it.
Not sure tbh ricky, do you have any water leaks?
Im starting to suspect mine is a blocked heater matrix, though the coolant is perfect, and was the same (no crap in it) when I dropped it all just before xmas
Will sling a hose on it and see if its got much flow
I heard they are supposed to be notorious for shit heaters though
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
