HELP PLEASE with omex 600 set up
hi guy's
Don't no if anyone can help im doin a 2.1zvh conversion to my s2 rsturbo and have fitted an omex 600 ecu the problem is i can't get it to fire up the ecu is reading the crank sensor (shows engine speed on cranking) but not switching ON the (stat sync) so no spark, if anyone out there is using omex set up and has any idears it would be a great help as i'm now pullin my hair out
many thanks
warren
many thanks
warren
i got a base map from omex but it still wont pick it up i have checked the gap from the crank sensor to the flywheel and it's 1mm so can't see why it wont sync
