DIY turbo rebuild?
DIY turbo rebuild?
Got a smokey T3 on my RST, noticed you can get rebuild kits on ebay, anyone had a go doing there own? think I only need an oil seal on mine as it still holds good boost?
I did my T34 and had no problems - But to be fair, I had bought it second hand and stripped it down to check everything.
Make sure you mark up the location of the compressor in relation to the turbine wheel otherwise they will be out of balance when you put it back together and the unit will vibrate itself to death due to a slight imbalance.
hadest part is making sure you put everything in the right place and making sure that there is no soot, carbon or other debris in the bearing housing when putting it back together
Stu @ MSD sells rebuild kits aswell for a vast array of turbochargers fitted to Fords over the past years
easy peasy mate just make sure everything clinically clean , also as stated make sure you mark all the housings in relation to each other
and important to mark and refit the compressor wheel in relation to the shaft for balancing purposes
and lastly dont forget to pre-oil it before firing the badboy back up
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
