Auto sparkies help ???
My mate had a peuguet 306 which the electris windows dont work. I have checked the puse which is ok but no power to the switch. According to the fuse panel it goes from fuse to a relay ?? Any idea where this relay may be ???? and according to some research my mate has done it seems to be a 3 pin relay (grey in colour ) wot does a 3 pin relay do ?? or is it some kind of resisatnce relay as when wound fully up or down it cuts the power ?? Any help much appreciated
i garantee the problem will be were the loom runs through into the door from the a pillar
had the same problem on my 306 dt and this is what it is ,,, also a right pain as you have to remove door etc and unplug loom were it joins the door, strip the rubber back and find the broken wires![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
good luck lol you will need it
i agree with the above dont go to peugeot the new loom they supply has no colour codes they use it to fix loads of different models and its a pain in the ass
He thought it was the switch cos the passnegr side stopped working but changed the switch to a 2nd hand one now neither works pmsl still pointing at the door wires ????
3rd
i done one the other month, pulled the loom through into the car, the silly twats fill the plug and were the wires go into it with sealer, right git, i had 3 broke wires, i used the soldering iron to melt the sealer away from the wires so i could get to the ends and resoldered, takes about 10 mins to remove the door just makes access etc much easier
yeah ill add to this by saying door loom is broken.used to change alot when at pug but never came coded and all the wires were black.had to use meter to find out what wire does what.real time consuming.best to repair if u can
