mig welder help
mig welder help
i am having another go at the five link upgrade to my Mk1 escort.went to the shed to start again after the christmas break but couldnt get the (newish) mig to run.its outputing a feeble spark like if you dragged a light earth cable across the positive on a battery.
i checked the following with no sucess,anyother areas before i drop it back to halfrauds.no wanting to do this as they will only send away and ill be without for weeks at least.
earth clamp attached fine
metal bared,ground it back
plus/neg connections at mach tight
shroud/tip removed and refitted
wire running through fine
different power settings checked
cover removed and nothing obvious
continuity checked on gun/cable feed wire
any ideas
cheers
rob v
any ideas
cheers
rob v
mig help
I suppose you could do the obvious checks like running a resistance check or voltage check with the multimeter make sure there is enough power getting to the unit. not much help but maybe a cause!
Live long and prosper!!
State to Halfords you need it for MOT work on your current car or you will demand a full refund
Or get someone else to buy the same pay cash and put your busted one in the box and tell them I've been told its not powerfull enough for what i need and get a refund job done
Paul
Paul
hoping for an expert to suggest an area to check to be honest as if halfords take it dont know when ill get it back.second unit is an idea tho although some other poor punter gets my hassle when they buy so not happy bout thet.
cheers
rob v
cheers
rob v
Neil S
29-07-2004 07:50 AM
